- May 10, 2004
- 69
- 0
- 0
Problem 1: Cable modem temporary loss of connectivity (i.e. Cable light is "on," computer has an IP addy but no pings are getting through) Power cycling the cable modem restores normal connectivity.
Now...I had been having the aforementioned cable modem problem all night last night. It's a new cable modem and I was attributing it to the fact that the downstream signal on my cable signal is slightly out of spec (it's 18 dBmV when it should be no higher than 15 dBmV)
I had plugged the modem into my secondary power strip (the one I use only for my desk lamp and clock radio) since my primary one is way way under my desk and I was too lazy to crawl under there to plug in the modem.
Then I remembered (Problem 2) that my router had also been plugged into that same strip. When that router was in service it was nothing but trouble...it rebooted for no reason and it frequently crapped out and had to be rebooted. I attributed it to the fact that it was a piece of crap router.
So I switched the cable modem to my primary power strip...i'll wait and see if the connection problems go away.
I had heard that cable modems and routers are really picky about getting a stable power supply. Could a crappy surge supressor really cause them to bug out?
