BonzaiDuck
I found these at Tiger and the Egg. Don't know why I hadn't discovered them earlier, since -- from other threads here -- you all would know I'm "looking for a fan:"
http://www.newegg.com/Product/Produc...82E16835553006
I thought to myself "113 CFM?!! Less than 20dBA?!! PWM!! 300--thousand hours!!??"
Maybe I jumped too quickly, and I usually order two fans for anything I'm apt to try out -- even if I only need one.
Looking at the cus-reviews, there is a low-rpm motor-noise. The Manufacturer -- in responding to those reviews -- said early last year that "it had been fixed."
Should I be optimistic? I need the throughput, the PWM, the longevity. I wouldn't mind air-turbulence noise, but these are supposed to be "silent." Not what some customers said, though.
I suppose I can test them out of the case before I take the time to remove my NMB-MAT and install the Cougar Vortex . . .
At least you can order them in black instead of orange. Why do I think the manufacturer is goo-gah about Halloween?
