Discussion Cost of foundation and prep work on a garage slab?
Ajay
16,094
8,113
So, the Mrs and I are refinancing our mortgage (rates are terrific). I'm doing some rough pricing checking on costs before the refi. The garage itself will be ~$20K (maybe a tad less depending on materials costs next year). I'm not sure how much it costs for a slab (say for a 22' square garage) is in New England. Anyone have a rough Idea.
The contractor we will be using is excellent, but he's been straight out this summer he hasn't had a chance to stop by - so I need to ball park it.
herm0016
8,515
1,128
figure 10 to 12 per sq foot for a 4 in slab with rebar and minimal grading. at least that's what it is around here.
not sure what you need foundation wise where ever you live.
Ajay
16,094
8,113
Thanks! Pretty much flat as a board and has asphalt for our off street parking already (which, obviously, will need to be removed).
Greenman
22,142
6,373
Slab is only part of the cost, you need a foundation as well.
I can't begin to guess at the cost because it sounds like you live in one of those places where water isn't liquid half the year.
Reactions: pcgeek11
Ajay
16,094
8,113
Yes, well, 4 months below freezing. I can’t remember what it’s called, but the slab 'sits' on concrete columns poured 3+ feet deep to get below the frost line.
Steltek
3,318
1,057
You mean a stem wall foundation for the slab?
herm0016
8,515
1,128
Almost certainly. A suspended slab would eat a whole bunch of budget in a big hurry.
usually just a stem wall/ perimeter wall 3 feet or so deep, you can monopour with the footing if you have the right forms. then build the garage on that, then pour a 4 in floating slab after its done. inside graded with roadbase. no need for a suspended slab with all that rebar and tie into the stem all.
i would consider a grade beam slab as well. depending on your frost depth.
that frost protected slab looks way more complicated than a grade beam slab or just digging a stem wall.
Ajay
16,094
8,113
Pics if this helps:
They can be mono-poured as @herm0016 mentioned. The DIY guys do two pours 'frost wall/footing" and separate slab. My contractor will sub that job out to one of a couple local concrete companies he does business with - so I'm sure they have all the right forms for slab foundations in NH.
Thanks for the input so far guys!
