Rip the Jacker
EDIT: FIXED Upped Mem voltage to 2.8
Ok.
My default memory speed was 166 MHz I just realized...
That is PC2700 speed. So I restart and go into BIOS. I use "AGGRESIVE" settings and it sets the speed to 200 MHz. I restart and I can hear the computer but I can't see anything on the monitor. (I didn't change ANY video settings).
I reset the CMOS and everything works fine. So i go back to settings and use "USER DEFINED" settings. I set it to 100% which is 200 MHz. Restart. Same problem : nothing on monitor. So I reset CMOS again and everything's fine.
By the way, I'm 200 MHz x 11.5 = 2.2 GHz. The A7N8X Deluxe has 1 Slot for PC2700 and 2 Slots for PC3200 and I'm using it on one of the two blue ones that are supposedly PC3200.
My ram is Corsair XMS 512MB PC3200 "CMX512-3200PT." DDR400...
Still not working at PC3200 speeds...
Can someone help me here? Should I get new memory?
Ok.
