CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory
Barnacle Bill
117
The timings on the Patriot memory are 2-3-2-5 which are better than the XMS timings of 2-3-3-6 so I'd buy the Patriot memory....
Jaxidian
2,230
twitter.com
On the flip side, neither are bad deals at all. And if you want memory, buy quickly! Prices are on the rise! We won't be seeing deals like this for much longer until prices drop back down (if that ever happens with DDR1 since AMD will be going to DDR2 before long).
brownzilla786
904
did anyone get back their corsair rebates from a while back when they had a similar deal, but the prices was around 120?
trexpesto
1,237
OK which of these, they are all about the same price??
* CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model Twinx2048-3200c2 - Retail
Cas Latency: 2
Heat Spreader: Yes
Manufacturer Warranty: Lifetime
Timing: 2-3-3-6
Voltage: 2.75V
* Model #: Twinx2048-3200c2
* ($138.00 after $50.00 Mail-In Rebate)
* OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Platinum System Memory Model OCZ4002048ELDCPE-K - Retail
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.8V
* Model #: OCZ4002048ELDCPE-K
* ($141.00 after $50.00 Mail-In Rebate)
* CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model Twinx2048-3200c2pt - Retail
Cas Latency: 2
Features: Platinum Heat Spreader
Heat Spreader: Yes
Timing: 2-3-3-6
Voltage: 2.75V
* Model #: Twinx2048-3200c2pt
* OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model OCZP4002GK - Retail
Cas Latency: 2
Features: Mirrored Platinum XTC Heatspreader
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.8V
* Model #: OCZP4002GK
* ($141.99 after $50.00 Mail-In Rebate)
* OCZ Gold GX 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory Model OCZ4002048ELGEGXT-K - Retail
Cas Latency: 2
Heat Spreader: Gold XTC
Timing: 2-3-3-8
Voltage: 2.8V
* Model #: OCZ4002048ELGEGXT-K
($146.99 after $50.00 Mail-In Rebate)
t3h l337 n3wb
2,698
The Patriot is only $117 after rebate and -$10 coupon code "BUYPATRIOT" I think, so go for it. I just did. If that's not the right code, look in the Newegg.com Hot Deals post.
