Question Corsair Vengeance RGB PRO 16GB doesn't work with MSI b450 Tomahawk Max
adamekcerv
Hi,
My motherboard (Tomahawk Max) doesn't work with Corsair Vengeance RGB PRO 16GB. There is no screen/display on boot. It worked without problem for a few months a after that the RGB turned red and I wasn't able to boot my PC. When I change the RAM to Corsair 16GB KIT DDR4 3000MHz CL16 it works. And the Vengeance RGB PRO also works with a different MOBO. Where is the problem ?
Thank you very much.
Odesláno z mého SM-G965F pomocí Tapatalk
ASK THE COMMUNITY
