Does anyone know if you are able to disable the LEDs by cutting any wires on them?
Reason is cos I want the fans to be in 1650-1500 range, when I down vote them to 7V, they be silent. 1100 rpm range fans at 12V are not quiet enough for me sadly.
the first question, i believe you need to break the led off.
the second question, makes no sense as you want them to be in the 1650-1500 rpm but 1100 rpm is not quiet enough?
Then why do you want them at 1650-1500 rpm?
http://www.tomshardware.com/answers/id-2595334/disable-led-corsair-af120mm.html
Pretty easy to do.
Also, it is 'volt'. You aren't voting.![]()
