Stefan Payne
- Dec 24, 2009
- 253
- 0
- 0
Yes but that's something you coud see relatively easy.If you are worried about that, then what color the cables are doesn't matter....they could just as easily hook up a yellow wire to a 5V and a red wire to a 12V if they are going to be making mistakes.
Even the man who does the cables could see it easily.
That happened before - with the 5.25" to 3.5" adaptor of the HX450...
Nothing.what do you have against the Chinese?
Maybe I should have written 'poor Chinese guy'.
Why not?My vote is no. You are obviously biased and have been banned from at least 1 forum for shilling and trolling AX1200 reviews. With that sort of bias so paynefully apparent, your review would be close to worthless since you cannot be impartial.
If I'm really that biased, you say I am, and the AX1200 is a really good product, than it should be rather easy to attack my criticism of the AX1200, so you have nothing to fear, if your product is as good you say it is.
So why are you so insulting?
