These are averages of about two weeks of monitoring.
Software should never be trusted, use a good meter.
CPUID HWMonitor
I installed two Corsair PSU's
One is a 750HX the other a 650TX
The 750 reads
+3.3 = 3.28
+5 = 5.0
+12 = 12.10
-12 = -14.08
+5V VCCH = 3.60
The 650 has:
+3.3 = 3.36
+5 = 3.32
+12 = 14.17
I am more concerned with the 650 as it just seems way off.
Any idea?
Seriously... how many times does it need to be said that software voltage readings should only be used as a rough guestimate and only referred to when there's actually a problem present (because if you actually referred to your software readings when there isn't a problem, you tend to knee jerk assuming there is a problem.)
There is a sticky here: http://forums.anandtech.com/showthread.php?t=257485
Also, make sure your wires into the motherboard are FULLY SEATED, especially the ground wires.
Well my father was getting BSOD's so there was a problem happening. I believe it's related to a flash reader though. I haven;t heard back from him since it's been uninstalled.
I didn't say this was a bad situation at all, hence why asking here. In the BIOS he is getting normal readings. I verified the other day.
Corsair wanted him to RMA it. I didn't think it was necessary.
CPUID HWMonitor
