I have an ASUS CUR-DLS mobo and will be throwing it into a 1U rackmount server. This mobo only takes ECC registered RAM (same mobo in the Gateway 6400s...). Anyways, I the 1U case can only fit low profiled RAM. Since I have a budget, I can afford either Corsair or Kingston. Are there any recommendations between the two? Or if I were to spend a bit more money, do you guys have any other suggestions? I'm looking for 512MB ECC Registered, Low profile, PC133 SDRAM. Thanks in advance...
