OK, so basically I am in need of a replacement for my Corsair H50.
Here is the info on my current rig that I think would be pertinent.
Case: Antec 1200 (Original, not V2)
Mobo: Gigabyte Z77X-UP7
GPU: GTX670 in SLI Configuration
CPU: Intel 3770K (skt 1155)
So the deal is that I got a steal on the aforementioned UP7 motherboard and I am in the middle of the swap out. In order for me to properly have my SLI configuration work, I have to use the top most PCIEx16 slot. That being the case, the radiator for the Corsair H50 blocks this slot. I have tried numerous different ways to mount the H50 radiator, but there is no way to both mount the H50 radiator, use the top PCIEx16 slot, and properly close my case. So basically the path of least resistance I am facing right now is to replace my Corsair H50. I will note that I just tested a Corsair H55 to see if it happened to have a smaller footprint that would allow me to reach my goals, but the H55 uses the exact same radiator.
My goal is to overclock moderately (not looking for bleeding edge, but am going to be pushing into the 4GHZ range).
I am open to air cooling options and if someone happens to know of a self contained water cooling CPU cooler that uses a low profile 120mm radiator that will not block my top PCIEx16 slot than that would be cool too. I have been out of the heatsink loop (pardon the bad pun) as it were for a while as I have been running my Corsair H50 for damn near 2 years without any issue and have been happy. Just trying to whittle my options down.
I am interested in options from the medium price range on upward. Thanks in advance for any suggestions you can send my way.
- J
- J
