What a disappointment!
I figured a gen 6 pump would be an improvement. Nope, considerably inferior to the H115i I swapped it out with!
It feels flimsy in comparison. The maglev fans are nice but it (the system) can't keep up with high loads.
Oh, and by high loads I'm talking 7980XE at 1.1V 4.6GHz all cores! I realize this is custom territory and that's the direction I'm going but for anyone thinking of switching, it's not going to please in the temp department.
And out of the box, the lighting effect is a changing rainbow! It can be killed with their link software but that doesn't save the settings (in a firmware like some AIOs) so you have to run it all the time. Last thing I want in the middle of a box is something that looks like a firework spinner!
It was tested twice, with factory application of tim and with Cooler Master Gel Maker Nano which does quite well. Both times temps were bad but consistently bad.
It is quiet though. The default fan profile is far too aggressive (quiet) though. Even at full speed, the maglevs are very quiet compared to the usual Corsair offerings.
