Corsair H100 in CM 690II Advanced?
IdBuRnS
155
Has anyone put the Corsair H100 into a CoolerMaster 690II Advanced? The case has two 120x240mm radiator mounting points, one at the top of the case and another at the bottom.
I'd imagine there shouldn't be any issues but wanted to see if anyone had any first-hand experience and some tips they could pass along.
Thanks!
itstsui
18
You should be fine, I'd put the radiator for the H100 at the top of the case. The 2x120 fan fittings at the bottom is more for bringing airflow into the case.
IdBuRnS
155
Thanks for the reply. :) I was planning on using the top mount but just wanted to see if anyone came across any weird compatibility issues.
Thanks!
