Corsair CX 430W Power Supply with Modular Cabling
Discussion in 'Power Supplies' started by paradigmGT, Jan 22, 2013.
  1. paradigmGT
    paradigmGT Member
    Jan 22, 2013
    55
    I am totally new to the world of desktop upgrades. I want to turn my Dell Inspirion 530 (~6 years old) into a machine that can run some decent games. It has an Intel Core 2 Quad Core processor (Q6600, 2.4ghz), 3gb DDR2 memory, 350watt PSU, & 2 hard drives (the oem 7200rpm 320gb & a WD Green 5200rpm 1.5tb).
    I decided to purchase a Corsair CX 430W modular PSU because it was on sale. It hasn't arrived yet, but I now worry that it may not work with my machine, because apparently some Dell's use different pin-outs. Is there anyway I can look at my machine and verify this?
    Also will this power supply be a safe bet with say an HD 6750 or HD7750 GPU?
  2. Loading...
    Similar Threads - Corsair 430W Power Forum Date
    No video on power-up using Skylake G4500 with Corsair CX430 Power Supply Power Supplies Wednesday at 1:18 PM
    Corsair CX 430W or pay a bit more? Power Supplies Mar 8, 2014
    Corsair CX430 430w with an i7 3770k, 5850, etc? beyond the limit of psu? Power Supplies May 22, 2013
    will I be safe with a corsair CX430 430w PSU to power my system? Power Supplies Feb 6, 2013
    Corsair 430w good enough for this build? Power Supplies Mar 8, 2012
  3. Torn Mind
    Torn Mind Diamond Member
    Nov 25, 2012
    3,065
    30
  4. paradigmGT
    paradigmGT Member
    Jan 22, 2013
    55
    The OEM PSU makes 350w peak.
    The Corsair I just purchased is 430w. I think I wasted my money on purchasing a unit that makes only 70w more than before. But then again that 70w may be the saving grace to a future failure...
  5. gazhen
    gazhen Junior Member
    Nov 6, 2012
    4
    I have Dell 530 and have upgraded my PSU to the Corsair CX 430 and have a HD 5770, you should have no problems.
  6. Torn Mind
    Nov 25, 2012
    3,065
    30
    The peak power of the Corsair can go higher than 430 watts. It's previous non-modular versions could pull up to over 500 watts, although under 80% efficiency.
    http://www.hardwaresecrets.com/article/Corsair-CX430-Power-Supply-Review/1200/8
    V2: http://www.hardwaresecrets.com/article/Corsair-CX430-V2-Power-Supply-Review/1284/8
    #5 Torn Mind, Jan 23, 2013
  7. max347
    max347 Platinum Member
    Oct 16, 2007
    2,322
    They make a modular cx430 now? Where can you find them?
  8. Necc
    Necc Senior member
    Feb 15, 2011
    232
    I'm running a HD7850 1GB with a Corsair CX430v2, if the card requires only 1 PCI-e connector then the CX430 is plenty. (unless crazy oc and 12+ fans :awe: )
    Newegg
  9. Eureka
    Eureka Diamond Member
    Sep 6, 2005
    3,828
    The CX430 is rated at continuous power, which means it'll peak higher than it's rating. The Dell, if rated for peak power, has a much lower continuous rating... for $30-50, it's not a bad upgrade to the CX430.
    Now, I actually think you could've scraped by with the 350W. Even if its continuous rating was around 300W, the Q6600 only needs 100W and the 7770 needs 80W. With the hard drives you might peak around 250W.
    That said, it's not a bad idea to go with the CX430, and the modularity will make things cleaner inside your case. The CX430 will most likely be enough for any single GPU upgrade you will have in the future, or at least until they switch over to a new connector type for GPUs. If the CX430M was available when I did my shopping it would be in my rig right now.
  10. Charlie98
    Charlie98 Diamond Member
    Nov 6, 2011
    5,897
    I've got a non-modular CX430 in my new HTPC build and it works fine, it's a lot quieter than I though it would be. TBH, the non-modularity doesn't bother me... I use every cable except the string of molex connectors.
  11. jonnyGURU
    jonnyGURU Moderator <BR> Power Supplies
    Moderator
    Oct 30, 1999
    11,700
    Incorrect. Because the CX is roughly based on CWT's DSAII platform, they assume it can only do 350W because that's what the DSAII does. But the Corsair has a double sided PCB and twice the number of rectifiers as the DSAII. So if you bought a 430W, you got a 430W.
  12. paradigmGT
    paradigmGT Member
    Jan 22, 2013
    55
    Thanks for the info guys. Time to see if I can cancel my Corsair order...
  13. Torn Mind
    Nov 25, 2012
    3,065
    30
    I doubt the system can even consume 300 watts. The 6750 is not a very hungry card, and the 7750 is even less so.
  14. Bman123
    Bman123 Diamond Member
    Nov 16, 2008
    3,218
    I have one in my sig rig, not a modular one and I have had no trouble with it at all and I am running a HD6850 on mine. It's a really good power supply considering how cheap the price is on it.
  15. blastingcap
    blastingcap Diamond Member
    Sep 16, 2010
    6,656
    Be careful because HP and Dell and others sometimes use unusually-sized cases, PSUs, etc. that makes their stuff incompatible with others.
