- Apr 1, 2014
- 5
- 0
- 0
Hello, AnandTech.
My PC specs are:
Processor: AMD FX-8150 Black Edition 8-Core @ 3.6 GHz - I am not overclocking it and don't plant to do so either.
Video Card: AMD Radeon HD 6790
Motherboard: Gigabyte GA-880GM-USB3 AM3+ HDMI microATX motherboard
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
OS: Windows 7 Ultimate 64-bit
Currently, I have 2 120mm front fans and the 200mm side fan as intake. I have a Corsair H100i with the fans at the top as exhaust and also the rear 120mm fan as exhaust. I believe this is the most suggested fan setup everywhere I have seen and it's doing me good so far.
There is space at the bottom for another 140/120mm fan.
My questions are:
1) If I get another fan for the bottom, should I use it as intake or exhaust? In addition to your suggestion, please tell me if it will interfere with the airflow or will actually prove to be good for cooling.
2) Should I get a 140mm or 120mm fan for this purpose?
3) Is it really necessary to add a bottom fan or should I just leave it as it is? Will it affect my temperatures at all, given the case I have?
My PC specs are:
My questions are:
