Question Corsair Carbide 275Q or NZXT 510
Dave3000
1,543
114
I'm planning on upgrading to a new build but want to replace my current case as well. Which case is a better quality case, the Corsair Carbide 275Q or the NZXT 510?
Dave3000
1,543
114
Is the Corsair H150i AiO easy to install in the Corsair Carbide 275Q or NZXT H510 case or should I go for the H115i AiO? I can afford the H150i.
aleader
502
150
Why not the Fractal Design Meshify C? I was debating the NZXT 510, but went with the Fractal case even though it was $16 CDN more overall. I like that it has a dark option for the glass, and two USBs on the front. Also has much better cooling from the reviews I've seen. The only reason I even upgraded from my cheap Rosewill Challenger is so I can hand it down to my youngest son and use some of the PC parts I have gathering dust.
DigDog
14,769
3,060
to be honest, if you buy a big brand, main line case, you are not gonna go wrong. The days of horrid airflow and sharp edges are gone, and i quite like the 275Q. Im not sure if the 150i fits, however you shoul dbe able to see this from the corsair website.
Fractal makes some amazing cases.
Reactions: Makaveli
