• We are currently experiencing delays with our email service, which may affect logins and notifications. We sincerely apologize for the inconvenience and appreciate your patience while we work to resolve the issue.
corsair carbide 100r vs corsair carbide 200r?
Dec 16, 2014
47
In a nutshell, 100R is slightly small in overall dimension than the 200R. 200R does not come with a window side panel by default, 100R does. 200R has 3 optical bays while 100R has 2. Both have 7 PCI-E expansion slots. 200R has 4 extra 2.5in HDD slots, 100R has none.
redzo
547
200r cons:
- No dust filters on top of the 200r: Dust filters for the 200r are expensive and purchasing them defeats the purpose of the cheap 200r case. The inside of the case is a dust magnet.
- 0 sound insulation: It's a noisy case. Every sound gets out through those honey comb air vents. The case is full of tiny holes like that. Still, it doesn't affect me that much since I use silent components.
- I keep it on the floor, near my desk and there is always the risk of spilling your drink on the top of it: every last drop of liquid will spill on to the mobo and vga through those honey comb air vents.
PhIlLy ChEeSe
962
Leaving a case on the floor under the desk, if you have carpeting it will act as a vacum cleaner and suck all carpet fibers into it. Plus the limited air flow under a desk, If you can't table top it I suggest a milk crate. To at least get it partly away from the fibers. On top of the desk you'll get better air flow.
