Corsair 650d front fan with 2x 120mm?
note235
I was wondering if anyone knows if the 200mm front can be replaced with 2x 120mm fans instead?
i have some scythe gentle typhoon coming and the front fan isn't loud (doesn't have the fan issue) but its louder than my 2 cougars that replaced the top fan
I just checked my 650d and the front mount is for a 200mm only.
I don't even know if you can mod it as you need an extra 4cm, and the only way to get that is to remove the drive cage/bay above the 200mm fan.
