I'm planning on going with the 600T for my new system build (which will happen as soon as I can get a P67 motherboard
). Anyway, this case comes with 3 fans -- one 120mm, and two 200mm. For other owners of this case: were the fans that Corsair supplied with it good enough for you, or did you upgrade these, and if so, what were your choices?
I'm wondering if there are options like Scythe or Nexus, particularly for the 200mm size, that will keep the case cool without introducing a lot of unnecessary noise. Thanks in advance...
