Corsair 600T cooling question.
xInhibition
I was looking at the Corsair 600T White and found out that the cooling wasn't that great. Bit-tech.net said that it may have been because the 200mm fan on top is more toward the front than normal. I was thinking about replacing the top 200mm fan with 2 120mm fans, would this improve airflow and cooling. I will be using the Corsair H50 for my CPU the CPU is a 2600K the GPU is a GTX 580.
stahlhart
Super Moderator Graphics Cards
Dec 21, 2010
4,273
77
I clearly don't know jack about the Corsair 600T. Sorry!
Rifter
751
If you remove that mesh cover on the top you will see it is already setup to hold a 240mm rad which means you can bolt 2 120mm fans to it no problems. Holes are already there.
ViviTheMage
36,189
87
madgenius.com
Majic 7
668
I'm using a H70 in that case. Specs in sig. 32C idle cpu, 55 to 60 loaded. GPU idles around 36 to 38, fan at 50%. Games at about 60c at 80% fan speed. AC at about 76F. The fans are crap though, replaced the top fan with a 120 because it wouldn't start unless I flicked it. Only replacement fans I've found are Xigmatek. Don't know whether to try them or not. I could only use one 120 fan on top because the H70 radiator and fans are in the way of the rear fan. I wouldn't bet on a H50 allowing a second fan to be placed on top either. Looks pretty tight, maybe with cooling lines on the bottom. Mine are on top.
Just checked with a H50 rad, it will fit with two fans on top but the cooling lines probably need to go on the bottom. Pretty sad I have both, but when I went to MicroCenter to pick up the case I got the fever.
