Corsair 300R Fan Allocation
Aldin_D2X
Hi Everyone,
I got a little bit over zealous on the holiday season and instead of upgrading one or two parts, I pretty much bought a new rig. (Don't tell my wife!) As part of the new setup, I really wanted to give these pseudo water coolers a go. I ended up installing the H80i GT in an exhaust setup with a push pull config. I am wondering what other fans I should include. I'll link a picture below for reference.
My Spec
- CPU: Intel 4690K
- Cooler: Corsair H80i GT
- Mobo: Asus Z97-a 3.1 USB compatible
- GPU: EVGA 780 TI
- SSD Samsung PRO 120 GIG
- HD WD Black 640 GIG
- RAM: GSKILL DDR3 2x8 GB Sticks
- Case: Corsair 300R
http://imgur.com/xQvo3kK
Things to note:
- CPU cooler fans are the corsair supplied 120mm
- The front of my case only has 1 x 140mm
- The side plate has two spots for 120 mm fans that are empty
- The top has an empty grill that could fit 2x 140 mm fans
Any feedback would be appreciated. The whole positive vs negative pressure topic has me a bit on the fence.
Thanks in advance.
-Aldin
For most standard case layouts, you want to maximize front-to-back airflow. If you have the push-pull H80 as a rear exhaust, it might be useful to add a second 140mm intake to the front (I believe the 300R supports 2x 140mm front), but much more than that is probably not an efficient use of money.
^^THIS^^
You will get a bit more flow with the 2nd front fan, both to your gpu/hdd's, and to lower part of the cpu area, which is always a good thing 🙂.
The only real reason to add fans into the top grill would be if you are planning to extremely overclock of your cpu.....
I did both of these in my Carbide Air540, mainly because:
A) I have no water cooling,
B) I had 2 new fans in my parts box, and
C) 'cause I could 😀
Thanks for the reply gents. So, should I just leave the top grill and side panel empty? I was thinking about closing the two off.
