T Tarca Platinum Member Sep 6, 2001 2,200 0 0 Oct 1, 2002 #1 Just put together a new system and it is only showing up as 256. Asus A7V333 motherboard. tried different slots same in each. I guess I need to take the ram back. Anything I am missing or could check? Thanks
B bendixG15 Diamond Member Mar 9, 2001 3,483 0 0 Oct 1, 2002 #2 Check the mobo spec to see max size memory per slot.
T Tarca Platinum Member Sep 6, 2001 2,200 0 0 Oct 1, 2002 #3 1 gig per slot... I just going to take it back tomorrow. Thanks
W Whitedog Diamond Member Dec 22, 1999 3,656 1 0 Oct 2, 2002 #4 Yup. Take the multiplied number and divide it by 8 (in all cases with 64Bit DIMMS) and you have the MB value of it. (64x64)/8=512 In your case, it's probably just a bad memory mod(if it IS labeled 64x64). Thanks
