hi
i HAVE ran a search here but they were all regarding overclocking the mobile and the amd website & forum have very poor documentation on the MOBILE XP
anyways, my set-up is:
XP-M 2400+ 45w chip
TT Silentboost cooler
Shuttle An35-N ultra 400 board
corsair value select 512mb ddr400 pc-3200 ram
I do NOT desire to run it overclocked, so i want the baseline setting where its designated:
133 bus (266fsb effective)
13.5x multiplier
and 1.45v cpu
is this correct?
(its sitting in this state @ 36* CPU)
the reason i question it is because , by leaving the bios in AUTO, it sets the config as so:
100mhz bus
6x multiplier
1.55v cpu
now i realize that both my ram and mobo are capable of running higher fsb... 166mhz.. maybe even 200mhz... and the multiplier setting, in conjunction with FSB, dictates the speed at which the CPU will run... so i may fiddle with it later on
my question is the Voltage... how does that affect the CPU? does increasing it or decreasing it add to stability? will it need to be increased or lowered to go along with overclocking? thakns
also... if the fsb is doing 133/266... is there a point in running the memory at ddr400? wouldnt it be bottlenecked by the fsb? leaving the mobo config in AUTO for memory results in ddr400
XP-M 2400+ 45w chip
13.5x multiplier
and 1.45v cpu
is this correct?
100mhz bus
6x multiplier
1.55v cpu
