Corner Shelves for Speakers
Juice Box
Do they make corner shelves (to hold something less than 5lb) that do not put holes in the wall? Perhaps some sort of rubber stopper that you can apply outward pressure on to make the shelf "stick" to the wall?I have no idea if such a product exists...I'm just trying to not put holes in my walls if I can get away with it 😛
u might have to buy ur own shelves, or make em of course. just a board sticking out would probaby be a bit stressful on the tape. i guess u can get one of those triangle or L shaped shelf bracked under it so theres more area to use that 3m pull tab tape, that would be fine.
there was that As seen on TV commercial for the exact corner shelf you are describing....
you should be able to google it...
