CoreTemp and UAC
CU
I am trying to start CoreTemp up when I start my computer/logon without UAC popping up. I don't want to disable UAC, so I created a task. It doesn't seem to be working though. CoreTemp doesn't start and I don't get a UAC prompt. Below is my exported Task. This is in Win7 64bit with the newest CoreTemp. Thanks.
<?xml version="1.0" encoding="UTF-16"?>
<Task version="1.2" xmlns="http://schemas.microsoft.com/windows/2004/02/mit/task">
<RegistrationInfo>
<Date>2011-06-21T22:08:01.8867187</Date>
<Author>Q\Eric</Author>
</RegistrationInfo>
<Triggers>
<LogonTrigger>
<Enabled>true</Enabled>
</LogonTrigger>
</Triggers>
<Principals>
<Principal id="Author">
<UserId>Q\Eric</UserId>
<LogonType>S4U</LogonType>
<RunLevel>HighestAvailable</RunLevel>
</Principal>
</Principals>
<Settings>
<MultipleInstancesPolicy>IgnoreNew</MultipleInstancesPolicy>
<DisallowStartIfOnBatteries>true</DisallowStartIfOnBatteries>
<StopIfGoingOnBatteries>true</StopIfGoingOnBatteries>
<AllowHardTerminate>true</AllowHardTerminate>
<StartWhenAvailable>true</StartWhenAvailable>
<RunOnlyIfNetworkAvailable>false</RunOnlyIfNetworkAvailable>
<IdleSettings>
<StopOnIdleEnd>true</StopOnIdleEnd>
<RestartOnIdle>false</RestartOnIdle>
</IdleSettings>
<AllowStartOnDemand>true</AllowStartOnDemand>
<Hidden>false</Hidden>
<RunOnlyIfIdle>false</RunOnlyIfIdle>
<WakeToRun>false</WakeToRun>
<ExecutionTimeLimit>PT0S</ExecutionTimeLimit>
<Priority>7</Priority>
</Settings>
<Actions Context="Author">
<Exec>
<Command>"C:\Program Files\Core Temp\Core Temp.exe"</Command>
</Exec>
</Actions>
</Task>
I have been meaning to do this myself. Will take a look at it when I get home. If using a task doesn't work, I will just use PowerShell.
On a previous windows7 installation I found a way to use scheduler to make this happen. I got lazy on my recent Win7 install and I just turned UAC off entirely.
This sounds like what I did and I dont remember it not working (ripped from another forum after googling "realtemp windows7 uac scheduler"):
Code:
Start > Programs > Accessories > System Tools > Task Scheduler
Action > Create Basic Task
Enter a name. RealTemp, GPU-Z, CoreTemp, whatever app you're running, or some random crap like Flugbuzonplipmen will work. Click next.
Select "When I log on" as the trigger. Click next.
Select "Start a program" as the action. Click next.
Browse to the executable, and add any parameters if necessary. Click Next.
Click Finish. Now whenever you log on, the program will start, with no annoying UAC prompt.
Well I deleted my old task and tried to create a basic task like listed above. The only other think I had to do was add run with highest privileges. And now it works. Here is my xml file for anyone that might want it.
<RegistrationInfo>
<Date>2011-06-26T23:18:55.4013671</Date>
</RegistrationInfo>
<Triggers>
<LogonTrigger>
</LogonTrigger>
</Triggers>
<Principals>
<LogonType>InteractiveToken</LogonType>
</Principal>
</Principals>
<Settings>
<StartWhenAvailable>false</StartWhenAvailable>
<IdleSettings>
</IdleSettings>
<ExecutionTimeLimit>P3D</ExecutionTimeLimit>
</Settings>
<Exec>
</Exec>
</Actions>
</Task>
