core speed of 9800 pro
ming2000
425
im thinking about upgrade my video card. but now i m confused by the core speed of the 9800 pro. i was told that old version 9800 pro has the core speed of 350 and newer one has 360. but when i find 9800 pro from newegg, it says core speed is 380 like below:
- Specifications -
Chipset/Core Speed: ATI RADEON 9800PRO/380MHz
Memory/Effective Speed: 128MB DDR/680MHz
BUS: AGP 4X/8X
Ports: VGA Out(15 Pin D-Sub) + TV-Out(S-Video/Composite Out) + DVI
Support 3D API: DirectX 9.0, OpenGL 2.0
Cable/Accessories: 2 Adapters, 3 Cables, 6 CD, Manual
Max Resolution@32bit Color: 2048X1536@85Hz
Retail Box (See pics for details) No Half-Life 2 coupon
Model#: ICE98-2H-ZAM
Item#: N82E16814161109
can anyone explain it to me? and how different from the lowest 350 to highest 380?
Cawchy87
5,104
they are talking about r350 and r360 cores. It is the type of GPU (Graphics Processoing Unit) that is on the card itself, not it's clock speed.
r360 is the same core used on the 9800xt so it supports more shaders when flashed to xt
r350 overclock higher generally.
ming2000
425
get it, thx:)
Gurck
Banned
Mar 16, 2004
12,963
Yep, the r350 & r360 are just model numbers basically, they in no way reflect the gpu speed. They could be named p and q, or 5,000,000 and 6,000,000.
