Question Core i3-2120 + H61 refurbished PC, HDMI audio out possible?
psolord
2,142
1,265
Hello everybody.
So I got a refurbished PC with a core i3-2120 and H61 chipset.
I would like to have audio from its HDMI port, like AMD and Nvidia cards. Is something like that possible or is there no audio hardware available in Sandys?
I have installed Windows 10 1909. Everything seems to be working fine, but I don't see an HDMI digital out audio device. Only the motherboard's audio is available.
Lol I feel like a buffoon, because I have a sandy 2500k since they came out, meaning I should know everything regarding sandys, but since it was on a P67 chipset, I never got to use its gpu part.
Any help appreciated.
Thanks.
ps I am posting this in the gpu section, because it has to do with gpu audio, but if it's the wrong section, please do move it.
mopardude87
3,348
1,576
I could never get audio to carry out the display port of a old Dell, i pretty much wanted a htpc and put the stuff in a standard atx case and slapped in a nvidia card for video/sound card. That and well HD2000 is trash for gaming anyways. I built this just yesterday btw, so was in the same boat as you and just opted for a nvidia card. Had that and a 750w unit sitting around anyways so why not.
Reactions: psolord
Insert_Nickname
4,971
1,696
The Sandy Bridge HD Graphics driver included in 10 is pretty basic. Also nukes all OpenGL support. Force installing the latest 7 driver (4229 is the latest, I think) works fine though. You have to get the ZIP version, and install via Device Manager. Otherwise the Intel install program wont let you do that.
Reactions: psolord
psolord
2,142
1,265
The default Windows 10 driver is version 9.17.10.4459. I did what you said with the have disk method and the version number went to 9.17.10.4229 indeed.
There is indeed a DisplayAudio folder inside the driver package, so I guess the hardware does support audio. How do I install this however? I have no hardware with exclamation marks, that would indicate a device in existence without a driver. :S
psolord
2,142
1,265
Thanks for your reply.
To be frank, it's mostly out of curiosity that I started this thread. I mean I can use the HD audio of the motherboard and connect it to my TV in or get a pair of speakers.
So far, the need for a video card is not apparent. I mean this old system can run the jellyfish samples of this site just fine.
I tested up to 60mbit, since there is no way I will playback anything above that. Also Youtube 1080p/60fps runs fine, so no need for a graphics card atm. Poor old Sandy still delivers. xD
Reactions: mopardude87
Insert_Nickname
4,971
1,696
It should install automatically. At least it did the last time I tried on my SB system (Celeron G465/Asrock B75M-ITX). How odd. Perhaps the board doesn't include the hardware for audio over HDMI?
In that case, I really don't know.
Reactions: psolord
Spjut
933
163
You could always try running Ubuntu or another distro from USB and see if you get it working there.
Reactions: psolord
maddie
5,191
5,589
Displayport, audio?
mopardude87
3,348
1,576
Displayport, audio?
Yeah i was under the impression you could carry it. It has more of a chance then the vga port LOL. I wouldn't know to much, my main rig has a AE-5 soundblaster with dedicated headphones. I can't bother with inferior options. I only tolerate it and well HD2000 is dumpster trash anyways no matter how ya put it. The 660 was a must anyways as its playing some older stuff so a win win there. :)
psolord
2,142
1,265
Good idea!
I made a live Ubuntu with Lili, but the same audio device appeared. No hint of an HDMI out one. So I guess there isn't one.
Oh well. Thanks.
