- Dec 19, 2023
- 3
- 0
- 6
Hello all,
Some time ago, my grandfather passed away and I was left his old computer. I have tinkered with the overclocking for the past 6ish years but my knowledge of the subject is quite limited, and the forums I combed through for information either end up on a cliffhanger or the final image solution link is broken. I'm aware this is an outdated system, however, I would like to set an overclock to 4.0 as well as time the ram correctly. I have run into a few notable issues where my own knowledge limits me, as this bios requires some fine tuning unlike some of the newer boards. Any help will be appreciated, and I'll link as much as I can.
For starters, the basic specs are as follows:
CPU: Intel Core2 Extreme 9650
Mother Board: Gigabyte GA-EP45-UD3P (Rev 1.6)
Ram: Kingston KHX8500D2K2/4G (4 sticks 8 gigs total)
Memory Module Specifications KHX8500D2K2/4G https://www.kingston.com/datasheets/khx8500d2k2_4g.pdf
I have updated the bios to the most current available.
My first issue is the overclock. I've found a few different forums recommending a few different voltage settings, but I can never seem to get it quite stable, as I think I am missing a few puzzle pieces, primarily some settings that are set to "auto" because I don't know specifics unfortunately.
My second issue is timing the ram correctly, for the same reason I'm not quite sure how to clock the CPU correctly; missing a few pieces.
Listed below are my current settings, which I've sorta cobbled together from various older forums.
And yes, I'm aware some of these may look silly and to those of you who are knowledgeable, please bare with my lack in knowledge if something looks way off.
Robust Graphics Booster ...............: auto
CPU Clock Ratio .......................: 9
Fine CPU Clock Ratio ..................: 0.5
CPU Frequency .........................: 3.80 GHz (400x9.5)
--> Clock Chip Control <--
>>> Standard Clock Control
CPU Host Clock Control ................: [Enabled]
CPU Host Frequency (Mhz) ..............: 400
PCI Express Frequency (Mhz) ...........: 100
C.I.A.2 ...............................: [Disabled]
>>> Advanced Clock Control
CPU Clock Drive .......................: 800
PCI Express Clock Drive ...............: 900
CPU Clock Skew (ps) ...................: 0ps
MCH Clock Skew (ps) ...................: 0ps
--> DRAM Performance Control <--
Performance Enhance ...................: [STANDARD]
(G)MCH Frequency Latch ................: [Auto]
System Memory Multiplier .......(SPD)..: [Auto]
Memory Frequency (Mhz) ..........800...: 960
DRAM Timing Selectable .........(SPD)..: [Auto]
>>> Standard Timing Control
CAS Latency Time .................5....: 5
tRCD .............................5....: 5
tRP ..............................5....: 5
tRAS .............................18...: 18
>>> Advanced Timing Control
tRRD .............................3....: 3
tWTR .............................3....: 3
tWR ..............................6....: 6
tRFC .............................52...: 52
tRTP .............................3....: 3
Command Rate (CMD) ...............0....: 2
--> Channel A <--
>>> Timings Settings
Static tRead Value ...............8..: [auto]
tRD Phase0 Adjustment ............0....: [Auto]
tRD Phase1 Adjustment ............0....: [Auto]
tRD Phase2 Adjustment ............0....: [Auto]
tRD Phase3 Adjustment ............0....: [Auto]
Trd2rd(Different Rank) .............8...: [Auto]
Twr2wr(Different Rank) ............8...: [Auto]
Twr2rd(Different Rank) ............7....: [Auto]
Trd2wr(Same/Diff Rank) ...........9....: [Auto]
Dimm1 Clock Skew Control ..............: [Auto]
Dimm2 Clock Skew Control ..............: [Auto]
>>> Driving Settings
Driving Strength Profile...............: 1066
--> Channel B <---
(Same as channel A)
--> Motherboard Voltage Control <--
>>> CPU
Load-Line Calibration .................: [Disabled]
CPU Vcore ...............1.22500V......: 1.27500V
CPU Termination ........ 1.200V........: 1.24
60V
CPU PLL .................1.500V........: 1.5-1.500V
CPU Reference .............0.760V........: [Auto]
>>> MCH/ICH
MCH Core ................1.100V........: [auto]
MCH Reference ...........0.760V........: [Auto]
MCH/DRAM Ref ............0.900V........: [Auto]
ICH I/O .................1.500V........: [auto]
ICH Core ................1.100V........: [auto]
>>> DRAM
DRAM Voltage ............1.800V........: 2.200V
DRAM Termination ........0.900V........: 1.100V
Channel A Reference .....0.900V........: [Auto]
Channel B Reference .....0.900V........: [Auto]
Any and all help clocking this thing to 4.0 and timing the ram right would be much, much appreciated. I'm starting to lose hope.
--> Channel A <--
>>> Timings Settings
>>> Driving Settings
--> Channel B <---
(Same as channel A)
>>> CPU
60V
>>> MCH/ICH
>>> DRAM
