- Jul 18, 2006
- 6
- 0
- 0
The processor's running at 38 idle - but the noise is intolerable (I assume it's because my motherboard only has a 3-pin fan header for the cpu fan -- none of the settings in the bios reduce the speed). I was looking at the zalman CPNS9500 but I thought I'd check for any first-hand experience or advice first? Quiet is the name of the game -- with the cpu fan disconnected the rest of the computer is barely audible.
I have a GA-965P-DQ6, a core 2 x6800 and a cm stacker 830 (so I've plenty of 120mm fans!). Any opinions would be welcome.
EDIT: I forgot to mention - I saw the zalman heatsink being recommended to other people with core 2 duo processors, but I do worry that the core 2 extreme might produce a bit more heat
