Core 2 Duo to i3/i5 based system
TBSN
So I've got a unique situation. Here is are the specs on my system currently:
CPU: e6420 C2D stock
RAM: 6GB RAM
MOBO: Asus PK5 Deluxe
I want to switch from my large P182 system to a smaller SFF miniITX system, based on this excellent article:
"gaming-in-tight-spaces-mini-itx-featuring-gigabyte-silverstone-and-prolimatech"
I've compared the benchmarks on Anandtech's awesome benchmark tool. I compared the e8400 to the i3 540 and the i5 670. All I'm doing is looking at the graphs, and it's hard to tell how much of a difference it actually is in usage.
The inexpensive i3 is closer in performance to the e8400, and the Core2Duo actually beats it in a few of the gaming benches.
If I decide not to upgrade the system completely, I'll buy an e8400, which isn't getting any cheaper. If I DO upgrade the system I'll be able to give/sell the P182 with the C2D system to my dad who can use all the space in the case to make a file server.
I'd ideally like to use the smaller i3, but getting getting the more expensive i5 670 is tempting. It's the same wattage too ( but perhaps the faster chip will still generate more heat?)
So, performance-wise and in subjective terms, how much faster would the i3 be than the e8400? And the i5?
Thanks for the input!
i have the i3 530 (2933mhz). from my testing with synthetic benchmarks, I would just barely put the i3 @ 2.93 ahead of the e8400 @ 3.0.
i also have the e6420 conroe. the e6420 is still a nice CPU for lga775 because of the 4MB L2 cache. my e6420 can reach 3.4 with a decent cooler. you may want to OC to gain more life out of the system.
i would advise against the i5 6-series unless you like wasting money. I would instead go for the i3.
if you do keep the lga775 system i would instead drop like a q9550 in there and call it a day. until sandy bridge comes out, this may be your best choice if you are looking for performance.
Even though I'd love to upgrade your logic is persuasive. The thing is my Dad is looking for a fileserver and I thought it'd be a perfect time to switch to a small form factor. The Antec P182 is great but the front door is broken and it's gigantic. Maybe I should just give him the case and get a smaller case for the 755 system I have now. The only thing is I would be limited by my full-sized ATX board.
Would it be worth it to upgrade considering that I'd be selling the current computer at the same time for about the same price? (~$500-$600)? I guess I could sell him the case, get a new case, and then buy him a cheap i3 system for the file server...
try an atom based build for a file server. invest the money saved from a traditional server setup into a good RAID card for it if you are serious. otherwise enjoy the savings because an i3 is way too much for a household file server.
i use a NAS on my network that holds all of my data (all pcs in my house use ssd's only). its powered by like a 500mhz ARM processor and uses very little RAM (32MB?). a file server really doesnt need a lot unless you are moving a boatload of traffic.
its your dad. id give him a new case at least, all the parts can be used inside for all he knows, but at least make it look new/nice on the outside. i really like lian li's mini-itx line.
Is the NAS self built, if not what kind is it? My Dad bought a 1 disk NAS but he can't transfer files to/from it with his Mac. Thanks for the heads up, didn't know it could be low-end like an atom.
Same case, but with 450W? Sounds good. Come early 2011 I'll look to that. May take a while for good miniITX sandybridge mobos to come out though... We'll see.
