It wasn't too tough to set up. I had problems with it in the past on that same machine, but I thought i'd give it a try again and it worked perfectly, except for that it looks like it's running 4 threads. When I had to do the setup for it, I saw the part where it said MPI should appear once for every core you have and it did; it showed twice. I'll have to try to restart it when I get home. The only thing I can think of is that maybe I mistakenly set it to launch as a service when i didn't want it to and now since I'm also launching it manually, that's where the other two cores are coming from...i'll have to check that later.
