Core 2 Duo E4300 Benchmark - fresh and hot
StrangerGuy
8,443
124
From the site on E4300 overclocking:
1.575V - 3709MHz (529 x7)
1.375V - 2996MHz (333 x9)
1.55V - 3294MHz (366 x9)
1.6V - 3420MHz (380 x9)
E4300 seems to like a high FSB.
EDIT: Got those voltages from the text, not from the CPU-Z screenies.
NoobyDoo
463
Here's what the images indicate :
E4300 (ES) with DFI Infinity 975X/G & GeIL Plus DDR2-800 4-4-4-12
Power consumption : 15W less than E6300
OC :
Voltage - Core Speed - Multiplier - Bus Speed
1.368v - 2996MHz - x9 - 333MHz
1.213v - 3294MHz - x9 - 366MHz
1.213v - 3420MHz - x9 - 380Mhz
1.138v - 3709MHz - x7 - 530MHz ( <- E6300 ? )
Looks good !
coldpower27
1,676
So from the results
E6300 Eng sample goes to
3709 MHZ at 530MHZ FSB with a x7 Multiplier at 1.138V
E4300 Eng sample goes to 3420MHZ at 380FSB with a x9 Multiplier at 1.213V
hardwareking
618
Well i guess its gonna be the pentium d 805 of the core 2 duo series.
Sweet overclocking comes our way.Low FSB and high multiplier goodness.
Duvie
16,215
It wont open for me but I am sure those voltages are wrong...everyone knows cpu_z above a certain vcore wont show it right anyways...
NoobyDoo
463
Some more info :
Test : X2 3800 - E4300 - E6300
SysMark2004 : 220 - 249 - 256
S Pi Mod 1M : 41.3s - 30.5s - 29.2s
PC Mark05 : 5317 - 5736 - 5843
WinRAR : 1016 - 1084 - 1140
3D Mark06 : 7647 - 8079 - 8349
JAG87
3,921
they are not.
these seem correct
it seems the higher the fsb the less voltage you need for the same OC. anybody with a 500 FSB board should have quite some fun.
Duvie
16,215
I am sure it is not...That 1.213v is exactly what cpu_z gives me if I set my voltages above 1.45v in the bios....I hope those reviewers are smarter then that...It could even be speedstepping, though I would think they would have had to disable it to get stable overclocks
Duvie
16,215
Originally posted by: JAG87
they are not.
these seem correct
that seems to go against common sense...
JAG87
3,921
yep it is weird, but you can get 3.7 with 1.575v and 3.4 with 1.6v it seems...
maybe the 1.6v run was not OCd to its max...
The-Noid
3,117
4
It doesn't appear as if the OC is done from someone who is really skilled in OCing as well. Time will tell how the serious guys do with it.
I am just glad the chip isn't a crippled version of the E6300 with 1 meg cache like it was rumored.
BlingBlingArsch
1,249
price, availability when? and didnt Intel announce price drops for the E6XXX for January? those E4xxx might become cheap cpus *fingerscrossed*
Duvie
16,215
IMO...I dont think we should expect too much from these chips...i think they will likely be very similar to the top rangeof the E6xxx series...I think what we may end up seeing is X6xxx series chips thta somewhere along the line had some failed L2 cache.
Maybe in later runs they will be advanced stepping but probably about the same time the E6xxx series would be also....
Avalon
7,571
178
I'm not expecting these to overclock farther than current Core 2 Duo processors, but I am expecting them to reach similar clocks without requiring a massively high FSB for $150-$160.
Duvie
16,215
QFT!!!
I also expect them with the less cache to take the performance hit....Depending on a persons uses this may or may not be neglible to them...
harpoon84
1,084
In case people can't access the site, here is a repost on Xtremesysterms:
http://www.xtremesystems.org/forums/showthread.php?t=126278
As expected at stock speeds it is slightly slower than an E6300, but is also slightly faster than an X2 3800+, which means the slated $163 price is justified from a price/performance viewpoint. Of course, not many people here care about stock performance, so it'll be the ability to get a decent overclock without the necessity of high speed RAM and 400FSB+ capable mobos that will be the real selling point of this chip.
Avalon
7,571
178
QFT!!!
Well keep in mind they will have the same cache as the E6300 and E6400, but in comparison to the E6600 then yes, the cache could make a difference.
