cordless mice/batteries
SherEPunjab
3,841
hi i was wondering something. i have acordless optical mouse. logitech. anyways, the laser light is always on. it fades a bit when not in use but otherwise it is always on. its been 1 month and my batteries are already low now. any suggestions for something more cost effective? or is there a setting i can do to make it use less power?
NutBucket
27,153
635
Get the rechargeable version? The MS wireless optical just turns itself completely off if your hand isn't on it. It's pretty neat.
SherEPunjab
3,841
i haven't had experience with rechargeable batteries are they any good? I should have gotten the MX700 or whatever. I got the logitech cordless optical mouse. i got a hot deal on it after MIR so i picked it up. if i dont' want to change mice, what can i do?
RossMAN
Grand Nagus
Feb 24, 2000
79,034
440
Does your mouse accept AA sized batteries?
What zip code do you live in?
Deeko
30,213
12
I've got a cordless logitech, also.
I haven't changed my batteries yet, been runnin since August.
SherEPunjab
3,841
does your light stay on? even when not in use? i think mine goes to a power save mode, but it is still on(laser), still draining the battery.
RossMAN
Grand Nagus
Feb 24, 2000
79,034
440
You should definitely invest in some good rechargeable batteries and a good charger as well.
Here's the current best deal, best of all it's only $12.99
Here are your local Big Lots stores.
$12.99 gets you a
Panasonic 3 hour quick charger
6 1600 mAH rechargeable batteries AA
2 AAA's
Deeko
30,213
12
yea, the optical light is always on.
SherEPunjab
3,841
$12.99 gets you a
2 AAA's
Is RossMan cool or what.
Thanks man!!!!
RossMAN
Grand Nagus
Feb 24, 2000
79,034
440
$12.99 gets you a
2 AAA's
Thanks man!!!!
You're welcome. It really is an AWESOME deal, I bought one even though I don't need it.
The batteries are great. Use them in our remotes, digital cameras, anything that accepts AA's.
SherEPunjab
3,841
$12.99 gets you a
2 AAA's
Thanks man!!!!
is it good for digital cameras too? Oh wait, are you the right person to ask for this ;)
RossMAN
Grand Nagus
Feb 24, 2000
79,034
440
SherEPunjab - These are just regular AA NiMH rechargeable batteries yes they are PERFECT for digital cameras and cordless optical mice.
If I were you, I'd buy two.
SherEPunjab
3,841
gracias senor
ChinamanatNCSU
1,160
I'm assuming you have This one?
If so, the light is always on. It dims when its not moving, and after a certain amount of time it goes into power saving mode where it flashes. My batteries last me about a month. Less if I game alot during the month, longer if I don't. So yeah I'd get some rechargeables. Its what my roommate did. Me, I'm waiting for another good deal on the MX700 :D
Deeko
30,213
12
yea, I've got that one, pthe black one w/ a keyboard. I love that mouse. Perrrrfect contour. Anyways...I still haven't replaced my batteries.
SherEPunjab
3,841
No, I have this one
Text
I too will be waiting for th MX700 if there is a hot deal. i'm cheap.
i heard it comes with rechargeables :) well, if the biglots rechargeables work out well for me, i may just stick with this mouse. :) its aight.
RossMAN
Grand Nagus
Feb 24, 2000
79,034
440
No, I have this one
Text
You could buy the new Logitech MX700 for
$59.99 after $20 off $75 coupon
$49.98 after $30 off $100 coupon (you do have to pad your order up to $100)
$46.84 @ Amazon.com after $5 off $35 coupon and $20 MIR
manly
13,316
4,091
So how well does the Cordless MouseMan Optical work for FPS (or other fast-twitch) games?
I recently replaced the original (blue) MouseMan Optical with the second generation MouseMan Dual Optical. Both are excellent gaming mice. I've been too chicken to try a cordless mouse, but the reviews for the MX700 have declared it ready for prime-time gaming. I'm wondering how the previous generation fares, as the new MX line is too pricey right now for me to upgrade.
Also, the rechargeable MX700 apparently needs to be recharged regularly; whereas from you guys it sounds like the previous generation will run on NiMH AAs for at least a month's time, which seems a lot more convenient. Not too mention I have a few Panasonic AAs lying around from the first Big Lots deal.
Kelvrick
18,422
In most cases, cordless mouse suck big ones for games like Counter-strike and the lot. Thats because no matter how high the resolution and the fps the mouse runs at, the limited bandwidth of the signals being sent is only so much. It'll be decent with the newer ones, but cords are the way to go. That, and my microsoft explorer 3.0 mouse is the best I've ever used. :)
<== monkey dance
Iron Woode
31,309
12,824
No, I have this one
Text
I bought the RFSOP-35 cordless/optical mouse from A4tech. It uses 2 AAA NiMH batteries and has a battery charger built into the mouse itself. It uses a USB cable that connects to the front of the mouse to recharge it. Its pretty cool.
manly
13,316
4,091
I went ahead and bought the (last-gen) Logitech Cordless MouseMan Optical, the tail-less twin of my current Dual Optical MouseMan.
I won't be installing it anytime soon, but when I do, I can compare the Counter-Strike performance between the two. I looked at the MX700 and it has a very slick design, but I actually didn't like the 4 extra buttons. IMO the rear thumb button is hard to get to and the tiny dimples above and below the wheel are microscopic.
All in all, I think the previous design bests the MX700 (besides looks) although I'm actually partial to the original ergonomic "MouseMan" design (used in the first gen optical mouse).
Btw, price is $60 + tax - $30 MIR at Best Buy (B&M or .com).
TNTrulez
Banned
Aug 3, 2001
2,804
MS Optical Explorer Cordless. MX 700 .
Both have no noticable latency in FPS (CS mostly, a bit of BF1949 ? ), tested by yours truely.
