copy of AOEII
lordofdeath
367
hi all
does anyone know how to copy a AOEII games ? i have this game and I try to make a copy of it so my original don't go bad and it can not play. can someone here help
Kappo
2,381
try here. I used cloneCD and it worked great...but there may be more info at this place (check the forums).
Supergax
639
I have used CloneCD to copy this game (of course it's for backup purposes only ;)). CDR-WIN, Adaptec and Nero wont' copy it.
lordofdeath
367
hi all
i get the cloneCD down. I try to use the cd to image thng and I try to read the subchannel for data and subchannel for audio but it does not work. it say something that my cdrw drive not work. My cdrw drive is Acer 10x8x32. I just buy this one from staples
please help me. or tell me how you copy your AOEII cd
thank you
bigbootydaddy
Banned
Sep 14, 2000
5,820
might not be compatible. check the hot deal forum, if it was a hot deal, then clonecd/purnproof/etc are always asked.
tm37
12,436
Check the clone CD Site and check if your drive is compatible. You also may want to check and see if there are any firmware upgrades.
