Copy and rename file using Visual C++ ?
larva
185
Hi guys,
Anyone have the source code for copy ,rename and delete file using Visual C++ 6.0 ? Thanks !
regards,
Larva
Argo
10,045
You need three API calls:
CopyFile(...)
MoveFile(...)
DeleteFile(...)
Look up the syntax in MSDN.
Adrian Tung
1,370
Another API that you may want to look at is the SHFileOperation(...) function.
This function uses the Windows shell to do the copy/rename/delete operations, so you also get the progress bar displayed for free. Pretty useful if you are dealing with a lot of files (or a few very large ones), so you don't have to do the extra work to make your program not look like it is not responding during the operation.
:)atwl
