foodfightr
Thanks, I'm debating which to use in my next build.
Originally posted by: suszterpatt
Air: cheap, easy to install, less space requirement, risk of damage from failure = low (except CPU fan). Less cooling power.
Water: Expensive, takes more time to set up, bulky, risk of damage from failure = high (water pouring all over the mobo). Better cooling, allows for higher clocks.
and Air: More noisy Water: Less noisy
Plus it's vaguely likely something might be mounted outside of the case, which would increase noise as the case wouldn't provide a barrier to sound.Originally posted by: JBDan
This is not always the case. The simple facts that you have a pump and still have case fans (especially for the rad which in most cases is on the rear w/ attached fan/fans and creates noise) & the psu fan, therefore sources of "noise" still remain. But obviously, your load temps will be considerably lower with water. Idle temps will be similiar, but a little lower than good air cooling. I debated WC'ing and just didn't see the need with my temps. If you are a heavy oc'er & don't mind the maintenance, then go water by all means. I'm sure setting up a WC'ing rig would be a lot of fun as well.
Originally posted by: mindwreck
I have my radiator mounted outside the case and its a bit quieter than my xp90+panaflo combo. With watercooling i got way better temperatures, but at the same or quieter amount of noise.
I think what crakajax was trying to say is that air cooling is going to be more noisy if both of them were to get the same temps.
