Cooling top of Geforce
TheFro
68
I have oc'd Geforce2 and was planning to cool the bottom (not the chip side) of the card and was wondering about the best method to do so. I have a fan that fits exactly on the 4 holes on each corner of the chip and was wondering if there is anyway to mount it either using or not using the holes.
Fingers
2,188
I wouldn't bother with doing it by that. just buy a card cooler and if you case has a spot for a card over the video card, install it there. That should supply it with plenty of cooling, along witht he rest f your case.
Biggs
3,010
You're better off overclocking the memory since it's the component that provides the most gain.
