Hi all.
I have the following rig:
xp2500 barton @ 2.156ghz (at the moment, temps are too high for my liking hence the speed.. vcore set to 1.65v, cpu set to 10x215, memory set to 3/3)
nf7-s rev 2 with 2.45nforce 2 drivers installed
maxtor 120gig ata133 hard drive
pioneer dvd-rom and pioneer dvd-rw drive
standard 350W psu (that came with the case, its a chenbro gaming box)
geforce 3 ti 200 using 43.45 drivers
the only problem im having is keeping the cpu and the case to a good low temp. now i have a 92mm fan at the front of the case and a 80mm fan at the back (it can hold a 120mm fan which i have, but my psu dont like it as it shuts down the pc) and i have an uprated 80mm fan on my falcon rock 2 heatsink which pushes 45CFM of air onto the heatsink rather than the 27CFM.
now i know my heatsink choice isnt great, although before its been keeping my girl friends xp1700 @ 2.2ghz rather cool, but not this barton for some reason.. but anyway.
im would like to buy the following but i wanted peoples opinions on them as i prefer hearing what people have to say about them before i buy..
Vantec Nexus NXP-201 fan controller (for upto 4 fans using a maximum of 18W per fan)
Thermalright SLK-900U or 900A whichever is better
Vantec Tornado 92mm fan for the above heatsink. (hence why i need to get a fan controller!!!)
Antec True Power 480W psu
i have got 2 120mm YS Tech fans (38mm depth type as well) and when they are both in use (for a limited time) the pc shuts itself down, so i gather i need a better psu to cope with the amount of power being drawn off of it hence the antec true power 480w psu, would this be enough?
Im really not sure about a controller, so if anyone has any ideas or suggestions, please let me know. and really the same goes for the heatsink and fan combo, but i gathered the more the air that can go on it, the better. anyone got any preferences?
please can someone let me know whether or not this above combo would be the best bet for my rig as the cpu temps under full load are about 50c to 52c and the system temps are around 26c to 28c. im wanting the cpu around or below 40c and as for the system temp, as low as possible. like i said, i have 2 120mm case fans, one to go on the back and then one to go on the side by or around the graphics card area (hopefully its not to wide!!) when i can find something to cut out a hole for it.
i look forward to the replies
thanks for the help guys
