Cooling solution for a8n Sli-Premium
Hey guys,
I have an A8N Sli-Premium with an X2 4400 and 7800 GTX (the gtx has an AC silencer on it). My temps are:
Mobo Idle @35 load 38-41
CPU Idle @ 36 Load 39-44
GPU idle @ 42 Load 54-60
These temps don't seem to extreme to me, but i've been having some problems that might be due to temps and I was wondering if there was some relatively cheap and easy solution that i could use for cooling (like a pci slot fan or something of the sort).
Thanks for the help.
better soltutions for cooling? YES.
Cheap? NO
your temps are great for cooling on air. If you want better temp's u would have to go with a high end water cooling set or TEC, or phase. Dont sweat your temps, your not even hitting high 40's under load.
Problems shouldn't be caused by those temps. Have you checked to see if PSU is getting enough air? It could be overheating.
Temps look fine (hell, they look great).
Only a Water Cooling System (like mine 🙂) could probably beat it.
What fans are on the case that you are using? I recommend couple of 120mm fans for quiet operation and more airflow. Antecs are good for that.
