Cooling Requirements
Illidan
33
I've got a Alpha 8045 heatsink with Panflo fan (sticker worn away, don't know specs) on an AMD Thunderbird 1 ghz, and a 42 CFM Panflo on the back of the case. Temperature is around 38 Celcius for the CPU and 21 for the ambient system according to the Bios, but it'll go higher during mid-summer and/or heavy load.
Can I put an Athlon XP 2400 in with this setup, or do I need additional cooling / better CPU fan? I'm not looking to do any overclocking.
Thanks.
pirred908
629
If you buy it retail than just use the heatsink and fan that comes with it. Thats my suggestion.
Cheetah8799
4,508
An Alpha 8045 might work if you don't overclock it. Give it a try!
Or look into getting a Thermalrigh 9xx series heatsink, or Zalman flower heatsink. Both are good choices if you decide to upgrade.
Illidan
33
Thanks! I'm goin with an Athlon 2200 XP.. should be a bit less heat then the 2400 (and 7 bucks cheaper), and the ambient temperature of the room is steadily growing colder.. will be until next spring :/
Jen
24,206
14
nothing wrong with the alpha 8045
get the 35w 2400+ or 2600+ 45w mobile xp ,
go with a 32 to 43 cfm fan
temps will be just fine.
Jen
yelo333
990
My suggestion: go w/ one of the mobiles, or the 2400+, and underclock till you are happy with the temps.
