- Sep 9, 2004
- 15
- 0
- 0
I'm in the midst of working on cooling for this athlon xp 3000 machine im building. I got a barebones kit off tiger direct, the soyo k7vme one. It's pretty nice, and a good price, except that the case is horrific for cooling. The only exhaust fan is on the power supply. My temps are 63C with the case sides off
so it's pretty bad.
Anyway what's the difference bettwen arctic silver and the ceramique stuff? I got some cermaique in the package i order, but...I didn't trust it as much as my old tube of artic silver 2. is ceramique supposed to be better?
And additionally I'm not just trying to get some fan setups going. I don't have too many hsf options, because the power supply covers the CPU in this case, so there's not much more clearance. I'm using a dynatron something or other HSF that has a copper core (aluminum surrounding).
So the fan isetup im thinking about, I'm getting one of those Logisys 3d fan cards, and i'll have an intake fan on the front of case. I'm also trying to use the holes ine the side of the case (for ventilation) to mount another fan, to help bring in air. So all these fans will basically bei ntake fans, and there's only the one exhaust on the powersupply. My question is will this setup work at all? I'm going to have a ton of intakes but very little exhaust. so i'm not sure if that does any good
Does anyone have suggestions on what I could try with this machine, besides get a new case?
