cooling question..
BmXStuD
1,474
Can i use a slot fan for the REAR FAN if so it will be this one (this one) and than use this one for the one that goes in front (in front) . Or do i need two of the 80mm? for front and rear heres my case.
(my case= Included Fans: None, Optional Fan bays: 2 X 80mm (front & rear)
Lord Evermore
9,558
You'll get better cooling by mounting an 80mm fan in the area behind the CPU, so that it can suck the hot exhaust from the heatsink out of the case. You may or may not need to bother with a fan in the front; most of the time they can't get very much airflow due to very small openings, so they don't make much difference and add a lot of noise.
A slot cooler would be useful perhaps if you have a very hot video card, since it could suck hot air off of it, but it's not generally necessary. If you use it anywhere but right beside the video card, it could end up sucking cool air out instead of hot, since hot air rises above the bottom.
BmXStuD
1,474
so your saying i just just order one BACK caSE fan and it will be good.
ALso does that mean if its EXHAST that if i put my hand behind the fan on the pc i feel the cool air on my hand or do hte cool air blow inside the case?
im ordering theesmaybe 2
Lord Evermore
9,558
Yes, exhaust means blowing on your hand behind the case. You probably won't need anything beyond that, if you're not currently experiencing any problems from heat.
Thermaltake smart fans would be fine, but I personally don't see the point to special types of fans. Just get a fan that blows some good air and isn't too loud, or a loud fan with a lot of airflow if you don't mind the noise. Panaflo L1A fans are quite good, they blow a decent amount of air and are essentially silent. The "Famous Brand" type you linked to before would work fine too, but I wouldn't know how loud they are or how reliable. Panaflo's are only 9 or 10 dollars, and are known to be reliable and quiet. Vantec Stealth fans are also spoken well of, and a lot of others that I just don't pay attention to. :)
Whatever you get, make sure the connector is what you can use. 3 pin connectors go on motherboard headers, while 4 pin connectors use the power supply cables like a hard drive. Some fans have an adapter so you can use either type. Panaflo fans also don't usually have RPM monitoring, so pay attention to that if you'd like that feature when using the motherboard connector.
I'm not sure about the Top Motor fans you linked. They're somewhat louder than is needed for this application, and so cheap that I'd be really concerned about the reliability. They're also sleeve bearing, which is less reliable overall than ball bearing.
BmXStuD
1,474
i been downloading and my cpu runs @ 50c w/ the fan its ually 60c UNDER 100% load now w/ new well a old 80mm fani got wit 2 missing blades it runs @ 54c under 100% load. Also i only feel COLD well AIR coming from back there i thought im suppose to feel the same hot air ocming outta of the PSU right?
Lord Evermore
9,558
You may or may not feel warm air. Changing the fan setup changes how the air circulates and stuff. Plus, if you get the air flowing well enough, the air doesn't have time to get very hot before it comes out, whereas with bad airflow it sits inside the case getting really warm before it gets blown out. As long as the CPU temp goes down, don't worry about it.
BmXStuD
1,474
man do i like LORDEVERMORE alway has the right answer! Alway answers my question!! ADMIN GIVE HIM THE MOD POWER!!
