Greetings.
built a new computer a week ago.
Asus P5B
Intel E6300 C2D
Thermaltake "Matrix" case
http://www.thermaltakeusa.com/product/Chassis/midtower/matrix/vd2000.asp
also using a Silverstone 500w ST50EF-Plus powersupply
I am not overclocking. I use the stock fan\heatsink with the E6300
I ran the intel TAT program and under 100% load i get temps of 55C
Idle temps are around 39C-40C ...this i assume is ok?
I have a 20cm fan on front of case..20cm fan on rear. powersupply has a 20cm fan on underside. Also have a 18cm fan on side of case..this is were i have a question.
this fan sits (see link above for picture) above the CPU. I have noticed other Thermaltake cases had this fan blowing in, onto the CPU. I currently have it blowing out.
which way would be better?
If you look at the case you will see that the CPU is surrounded by 3 fans- 20cm on rear, 20cm under powersupply and 18cm on side. (plus the heatsink fan)
So in closing, side fan, blow in or out? I would probably look to overclocking later on and would get a better than stock heatsink\fan
