I am planning to build a system utilizing the Iwill KK266 motherboard + 1 GHz AMD Athlon Thunderbird.
I have decided to use Enlight 7237 case.
Should I go for the standard 250W power supply or upgrade to 300W
The case comes with a front case fan.
What are all the cooling devices that I am going to have to buy additionally for the case and the CPU? Please recommend an economical solution that will give me the best performance. Where can I purchase these items at a good price/
Thanks in advance,
Dhanu...
Thanks in advance,
Dhanu...
