I get the temp from the ASUS utility, so I think it is an average. It climbs up steadily and tops out after a couple of hours at the 50-51C.
The problem with my case is that the HD brackets are right over the CPU/Fan with little clearance above it. Otherwise the case ventilation is good, a front fan pulling in air and the power supply pushing it out.
Should I get a shorter fan to allow more clearance and thus better air flow?
Thanks,
Karl
