Hy guys, greeting from Sweden!
Now, I´m about to buy the Antec Plus1080AMG 430W True Power. Down bellow u can see the soon to be PC config.
1. How many fans is really necessari vs. the noise? The True Power (430W that comes with the case) I hear is GREAT, and the case has also already two fans installed in the rear, i guess theses two fans are ok or? Didn´f find the specs. on them. The optional fans 1 front, 1 HDD, 1 side panel, I guess that for each installed fan the noise gets louder even if they emit 12db, or if one installs maximum amount of fans maybe the cooling gets so efficient that the fans don´t need to operate that much hence less noise. Guys whats your oppinion?
2. Which 80mm fan do you prefer if u want to keep the noise down, what do u think about Papst 80mm 12db??
3. Same criteria but for the pcu on the socket A (soon to be computer on the bottom/reminder)?
4. I have the Creative GeForce 4 Ti4400, I think its a good card but its fan is a bit to noisy, can I solve this, suggestions?
