Cooling Help
sammy g
436
I am upgrading from a 500e@715 to a cbo 650. The board I'm using is the MS 6309. My question is what is the best, affordable cooling solution. with the 500 I was using the retail fan/sink. what could I expect to get out of the 650 with the retail components and would it be worth it to buy cooling hardware?
mechBgon
Oct 31, 1999
30,699
I don't know if you can call it affordable or not but an Alpha PAL35T would certainly do the job. Picture here: http://2cooltek.safeshopper.com/1/114.htm?58, you can also pick them up at many other good places. Look at it this way, it's forward-compatible, right? The GlobalWin FOP32 would be a lot of heatsink for the dollar, but if I understand correctly, they don't have &quot;feet&quot; to keep them from getting crooked on the CPU. I suppose you could add some yourself...
Ulysses
2,136
Maybe check the Cases &amp; Cooling forum too.
Thread starter Similar threads Forum Replies Date
P CPUs and Overclocking 1
Similar threads
ASK THE COMMUNITY
