cooling for xp3200+
langdonx
I'm looking to buy the new 3200+ barton processor and I'm having trouble finding a good quiet fan/sync for it. Thus far, this is the only thing I can find (suitable for 3200):
http://www.compuhq.com/tha1vo10hipe.html
Everything else I look at is only 2800+ or so. Ideally I'm looking for the quietest highest rpm fan I can find.
Any suggestions for the processor I want?
Thanks,
They probably just havent updated their webpages to take into account the new 3200+ processors. The SLk800, SLK900 are about the best heastsinks on the market. I paired mine with a high speed Panaflo fan and it gets good airflow with decent noise. These variable speed fans are a good idea too, you can find your performance/noise sweetspot.
