Cooling for Titan X
piowoc
Hi,
I will be using ASUS GeForce GTX TITAN X mostly for video and photo editing (Adobe creative suit), so no gaming at all. Do I need any extra cooling for it, or is the build in fan sufficient?
Thanks!
Yeah, that case has plenty of good airflow, so you should be fine.
If anything you might just need to add intake airflow, but I really doubt you're going to run into any issues.
