Started to build my first project, MOBO has two 3pins connectors, one for CPU the other sys fan (already dedicated for the back fan).
Will add one extra fan on the front of the case and perhaps a second on the side.
What if any advantage on using the MOBO vs the 4 pins from the PSU?
2) and if better to use the 3 pins are there splitter cables to hook 2 fans on a single outlet?
3)Will the extra fan on a single outlet create a supply/overload on that outlet?
thank you for your help
David
David
